D
Deleted member 6183
Guest
Maybe have it serviced at an Indie?
We both know that most dealers would still try to argue that it's your fault and that they're not paying for it.So take the warranty out of the equation and the Consumer Rights Act is your only protection, now take your car to a dealer & he tells you they've destroyed the ECU & the car will not run without a new one & you're paying for it! How long do you think that would stand in a court of law before you were awarded damages? I'd guess about two minutes in court would be enough for any judge.
Possibly, though STAR shows 'current software version', and also most likely runs some sort of CHECKSUM (although this may apply only to the new software?).Dealers cannot tell that new cars have been remapped unless you go on a road test with the datalogger running and then after your drive cycle carefully compare the actual data to standard readings from another car (that has also been run on the datalogger) to see of there is any differences, you would really have to go looking for it to find it which tbh i dont think any of the workshop staff would really go to that extremes as it would work against them financially
I agree whole heartedly with this. I do think you get used to the cars power increase and lose sight of the difference over time that it had made. I've been caught on the hop a few times at certain rev ranges and gears. I think it's about learning where the curves peak and how to get the best out of the torque. I know it's only a 250d, but since the remap off the mark in sports+ is significantly different. Iast year I had a new A6 Avant 3.0tdi remapped and can honestly say in certain areas there doesn't feel much difference if you get it right. Yet get caught on the hop and you've egg on your faceIf your map was only providing 10 % uplift (circa many modest maps) and depending where the curves changes are, a ''better" driver, with better tyres, getting a better drive, already in a better gear off a roundabout will eat into any 10%
Ahhh I see.. So it's just a flag that shows up. Doesn't actually inform them it's been actually remapped?Think of it like this, dealer goes to run an update on the pcm and it hasnt been logged properly on the (we call it the wasp at jlr) next time that vehicle comes in it flags up its due an update (that has been done already) so its done again, so now has this vehicle had 1 remap and an update? No its just had the same update done twice
Yes, it just shows its been flashed X number of times. There will be a version number logged but the remap could simply be called the same as the original.Ahhh I see.. So it's just a flag that shows up. Doesn't actually inform them it's been actually remapped?
Those "2.5" engines also had different, restrictive inlet manifolds than the 3.0 which were worth swapping. It was a more or less straight swap.That's because it's at the upper end of tuning with it's current hardware , unlike old BMW 525D which is a detuned 3.0 D - straight to Stage 2 for Stage 1 530D figures .
I've heard a lot of recent talk about remaps not being so good on modern engines.
Ford looked at using the 1.5 3 cylinder in the upcoming Focus ST, but they could not safely get more than the 200bhp it has in the Fiesta.
