grainqey
Hello,
I have a couple of stupid ideas - as you do when your a yobo with a W215 CL
firstly, how much do the precats actually do compared to the main cats? are they sufficient to pass an mot with a hot engine for example or do you need the main cats?
secondly, i've not got resonator boxes - just cats then the backboxes which i've had opened up with the intention of making it a bit louder but i welded them back up and have decided to dig a bit more before vandilising them - i've got a spare catback coming so i can chop at will soon...
can you just remove the baffle in the middle of the backbox between the two halves or what? i thought about cutting out the "S" of perforated pipe inside the backbox and replacing with a straight piece of perforated pipe
OR
would the removal of the main cats increase the volume without bringing the engine management light on?
thanks in advance
Alex
OR
thanks in advance
Alex
