- Feb 22, 2010
- Location
- Stirling, Scotland
- E55 AMG W211, E250 Sport W212, (and some Imps)
Any decorators / painters on the Forum ?
I’m not either but I’ve got a decent bit of knowledge on some aspects - what do you want to know?
The painting certainly is one area where if you’re quite finicky you can do a good job; investing in good brushes like Purdey will also help make your job a whole lot easier.The refurb is well over budget with almost the entire house ripped out.
We cant save on plasterer/joiner/plumber/bathroom/kitchen as these really need tradesmen.
Thought we'd save on the painting or at least the emulsion on walls/ceiling as well as the cleaning with sugar soap etc.
The branded paints you buy from Screwfix and B&Q etc are a DIY paint and quite thin, they don’t sell that type in painters merchants - it might have the same brand on the tub but it is different quality.Before I bought Screwfix trade paint I tried branded Crown emulsion and Dulux , coverage was not as good!
Thanks, that's exactly where we are.
What size roller did you use?
The branded paints were bought from my local specialist paint wholesaler who mixed all my external paints for both render and wood to a particular colour. The Screwfix trade covered bare plaster walls in one priming coat and two normal. Doubt any emulsion will cover in only 2 coats coats on fresh plaster, I stand to be corrected by a professionalThe branded paints you buy from Screwfix and B&Q etc are a DIY paint and quite thin, they don’t sell that type in painters merchants - it might have the same brand on the tub but it is different quality.
That’s what I used when I had my own Property services company - a sprayer , I had a Graco, with all the the different tips extensions etc I must of spent a good £2.5k on the kit but I easily got my money back. The finish is better and it takes less time. I sprayed everything, walls, ceilings and Trim. I went on a course to learn how do it properly as you do get a quite few problems and it can horribly wrong, if you don’t know what your doing, technique, temperature, viscosity, pressure and tip size all effect the finish. Plus you’ve got to get good at masking ( and enjoy it because you do shed loads) otherwise you will suffer from overspray and paint pulls from the masking tape. But once you know what your doing it’s an amazing bit of kit. The money maker is in the trim, I would take all the doors off and stand them up at a 90 degree angle to each other with a wooden batton screwed across the top of each of them to stop them failing over. Then I could do each coat on about 6 to 7 doors in about 5 minutes. I used Tikkurila paints which are very fast drying and give an excellent finish and high scrub rating. I always did 1 primer and 2 or 3 top coats depending on specs and a quick sand in between coats with the festool sander........and then you can always do what I did and buy a spray gun (Wagner) .....
I asked Valspar what the difference between trade and "idiot" paint is and basically, they said trade is more runny and ergo more difficult to apply but covers quicker. Apparently us DIY numpties want a non-drip paint that is a pain in the ass to apply. Personally I see it as a marketing con to make DIYers pay more. I'd purchased a can of 'idiot' paint and needed more - there was no stock (of idiot paint) and Mrs Valspar offered me the trade (base colour) and said..they are the same....who knows.....................
That’s what I used when I had my own Property services company - a sprayer , I had a Graco, with all the the different tips extensions etc I must of spent a good £2.5k on the kit but I easily got my money back. The finish is better and it takes less time. I sprayed everything, walls, ceilings and Trim. ...........
