On my 98 SLK LHD I suddenly got problems with the window on the passenger door. It would stop about 2-3mm too high. I adjusted it with the window switch. I was still able to get the roof up and down.
I got the door card off (with help of my mechanic) and found two small angle shaped metal pieces.
The angles are 26 x 17 x 2mm, and 30mm wide. They seemed to have been glued on the biggest part, one on the inside and one on the outside. The small hole on the smallest part are without threads.
It is very cramped inside the door and we did not find where these pieces should go.
I later talked with a friend who has fiddled around with the windows on his R107 and he said it was definately window stoppers. but he did not know anything more.
The mechanic that helped me has worked many years at the local MB workshop, but he did not know anything more neither.
At the moment I am a little scarce with my funds
so I will not take it to the dealer without knowing what it will cost.
Most things get fixed by this mechanic I know, but here he doesn't know.
Now I cannot get the roof down neither, I had all the microswitches adjusted 2-3 years ago.
Does anybody know how to fix this?
Or can anybody tell if it will cost a lot or just an arm and a leg?
