map747
Hi folks.
just removed the actuator that controls the air to the windscreen...pig of a job..., as it wasn't working properly, When the actuator is powered from the car, the actuator arm continuously moves through 270 degrees back and forth it does not stop. I assume that once the direction has been chosen the actuator should stop rotating?
So do you think i need a new actuator or is there a fix i can carry out on it?
My car is a 2002 Ml 55
Many thanks.
Martin.
Many thanks.
Martin.
