I have a COMAND fault on an ’06 CLS55 where, in use, it occasionally does a sort of soft reboot (not fully back to the Mercedes logo like when you switch it on) and flicks back to a blank screen with lines before resuming the function it was in before in about 5 seconds. It breaks the audio on CD or Radio and can remove the map while you’re looking at a navigation instruction .. which is really annoying! Also, the TV function works perfectly some of the time, then goes into a black screen with a slight line-flicker and a repeating thunking noise.
Had it down in PCS and Olly was confident it was a common failure fault with COMAND where it degenerates over time to complete failure. Replacing with new is prohibitive at around £2.5k, but it seems the odd 2nd hand one comes up around £3-400 on eBay.
My question is whether or not there is anything at all I can ask or do to prevent getting another dud if I go along the 2nd hand market option. This surely must be some sort of engineering material failure if it gets progressively worse? Is there any repeatable test I can get a seller to perform? Alternatively, does anyone in the UK fix such faults (I found a US firm which sounded like it did) .. assuming it’s cost effective!?
Anyone have one for sale here after a head unit swapout or similar!?
Really poor form with MB considering the price of the unit .. doesn’t seem like the type of failure that one should expect to be common.
