hi maddog,
i bought a dension i pod kit for my e211 with the most kit i would not waste your money.they work but you have to use it like a cd auto changer indeed it works by kidding the most ring that it is a cd changer.i also got the bluetooth adapter so i could use it with a phone,great to answer the phone you have to select disc 5 and press track forward its safer to use it in your hand.however it does play the i pod and you can forward and reverse track. i have taken it out i paid £325 including the bluetooth adapter it is the gateway 500 if you look on the desion website it is new if you are interested you can have it for £100 if not fleebay
hitch
YesI would be interested but i think my car is D2b is it the same ie fits on the fibre optic feed to the cd changer???
Umm shouldn't that be "No". The D2B and MOST models are completely different and incompatible. I suppose you may mean "Yes it fits on the fibre optic ring" which may well be true but you can't use hitch's.
I have a Gateway 500 and really like it but I have a separate Mercedes phone kit so can't comment on their bluetooth interface.
hi maddog,
hitch
