DIAG D2B Components
CLKKOMP
Ok Guys I have a question
In the comand diagnostics screen from holding down mute and buttons 1&2, I select Diagnostic and D2B Components mine reads:
POS Actual Config
000 180 1C8
001 190 0F0
OFF 000 190
OFF 000 000
OFF 000 000
Another clk meber on the forum (thanks Alex) reads these setting
POS ACTUAL CONFIG
000 IC8 IC8
001 OFO OFO
002 IF8 IF8
003 I90 I90
OFF 000 000
OFF 000 000
What does this info relate to?
Could this be why im having problems with the tv tuner as my comand is not setup probly in my car?
I can now get a great picture in tuning mode, teletext on any channel but i still cant store a tv picture?
The AV inputs are fine but still no joy, can anyone advise me further could this be a wiring issue on my part?
Neil
If you are near feel free to come over and swap over our tv tuners. (PM me).
(Steve)TV Tuner on D2B................sorry, must be asleep.
the tv tuner does not use d2b .If you can tune to a channel then you should be able to store it on a numeric memory key same as you do with radio stations.
POS Actual Config
000 180 1C8
001 190 0F0
OFF 000 190
OFF 000 000
OFF 000 000
POS ACTUAL CONFIG
000 IC8 IC8
001 OFO OFO
002 IF8 IF8
003 I90 I90
OFF 000 000
OFF 000 000
Neil
This is a D2B ring read-out and it means you installed some new hardware (=OFO) that was never updated into head unit memory and that its position is between the head unit (=IC8) and the original option that was there (=190)
Your friend has 4 D2B options and they are correctly stored in Head unit memory.
As a guess I take it that you installed a CD stacker and that your friend has a BOSE sound system with phone and CD stacker.
