tjamesbo
- Jan 6, 2007
- Location
- Sutton Coldfield Midlands
- CLK430 ,Vito V6 sport ,Jaguar 2.5 X type ,W124's 1993 220TE , 1994 320TE ,Mastercraft X5
Hi Last year my 1993 220TE just scraped through on emissions so am looking to avoid a fail this year ,It gets an " italian tune up" on the way to the MOT centre which is 35 mins away so its plenty hot and had a good high rev clear out on the way Current thoughts ;
1 I have used dipetane in the past cant remember whether any was in last time or not but some will be going in this time for sure
2 perhaps a dose of cataclean would be a good pre measure not expensive
3 run some injector / fuel cleaner now well before the test ( due 11th Feb )
not done many miles since replacment cat was fitted and same for lambda sensor
4 Clean Throttle Body ?
5 New Air filter ( oils is fresh only done a 1-2000 since changed in august )
Any clues from the readings ? i know there are some that can read these and tell what needs doing and how far away from what it should be it is
It seems to be the Hot Idle thats the problem (Fails on first ) and the CO level , any other concerns / indications from the readings/ measurements attached ?
and no it is not a CLA shooting brake LOL
Thanks Boyd
Thanks Boyd
