- Jun 24, 2008
- Location
- London
- 2022 Hyundai IONIQ 5 RWD / 2016 Suzuki Vitara AWD
I am not being unsympathetic, but he garage didn't charge you £800 for fault diagnosis, they charged you £800 for replacing parts which may or may not resolve the issue (and, in the event, didn't), and I understand that you have agreed to this?
I think it is all down to what has been said.
If it was "your problem is a faulty ECU, we will replace it and it will cure the problem", then you are right and they should put back your old ECU and not charge a penny. Same goes for anything else they replaced.
But if they said "we recommend to change the ECU, as it might be causing the issue, but we are not sure, so you should be aware that it might not resolve the problem" then this is a different story.
