Blueovalcraig
- Jun 29, 2015
- Mercedes C180k
Hi Folks,
Just had the car at the garage and it has the following DTCs
P2035 - Control Unit (ECU)
P2036 - Secondary Air inlet
P2029 - Road Speed Signal
P200A - Throttle Potentiometer
P201B - Random/Multiple Misfire detected
C1024 - CAN Communication with the engine system is faulty
C1210 - +30 Voltage, below lower threshold
C1161 - Yaw rate & Lateral Accelerator Sensor, Plausibility error YAW rate speed
C1173 - Steering Angle Sensor, Implausible
C1172 - Steering Angle Sensor, Internal Fault
Do you think these could be linked, i.e. could it be water ingress at a terminal or something or is the car knackered??
