vtechnician
- Feb 1, 2012
- mercedes c230 w202
Hi people
I am from South Africa. We have a workshop specializing in Merc repairs.
I have used the star diagnosis on newer models w202,w210 etc. and fully understand how all this works.
I have only recently built an LED blink code reader for a w124 220E with a 111 motor (HFM-SFI).I tested this and it works great.
I have started with the later technology and am going backwards.LOL
On older mercs with the continuous injection system,I know that on/off ratio tests can be done from the diagnostic socket "X11" thanks to this forum.
My questions are:
1)On a w124 230E with a 102 motor,the X11 socket does not have a terminal for pin 3.Can on/off ratio tests be done on this vehicle? If yes,which pin do I use?
2)This w124 also has the X92 additional diagnostic socket but there are only 2 terminals in the socket pin1 and pin7.I know that pin 1 is ground and pin 7 is for air-conditioning.Can the blink tester be used to get codes for the air-conditioning system?
I have checked the following vehicles and they have Pin 3 in the X11 socket:
W126 300SE 103 Motor and W126 500SE 117 Motor.We repair alot of these older mercs and have been testing the components/wiring without the on/off ratio tests.
Thanks in advance.
My questions are:
Thanks in advance.
