IanT
Hello all, I have a strong smell of diesel especially when idling, so I removed the engine covers and can see what looks like a valve mounted on the fuel rail that's leaking from it's centre.
I've used a parts catalogue site to give me the part number but I'm none the wiser as to what it's for, unless perhaps it's an air purging valve to expel air caught up in the system. I can't see whether it has any interface with the fuel rail bit it doesn't look like it. The part in question is part no 49 in the diagram (A611 078 03 49).
The catalogue suggests the valve itself isn't available but that's probably just code for 'please order an up to date part instead, these leaked...'
Can anyone help, is this an easy part to change? The fuel line attached to it appears to be heat shrunk on and might be very difficult to remove.
Cheers,
Ian.
Cheers,
Ian.
