I have said it before and i will say it again.
Normal aspirated Diesel does not stand a chance.
If you stick a turbo in as most diesels have ,then please stick one in the petrol as well , and if you do, no comparison again.
These are figures form VW non turbo diesel
output diesel 1.947 kW (64 hp) / 50 kW (68 hp) @ 4000 rpm, 125 N·m (92 lbf·ft) @ 1600-2800 rpm / 133 N·m (98 lbf·ft) @ 1800 rpm
Absolute rubbish
petrol 1.8
output 66 kW (90 hp) at 5500 rpm, 145 N·m (108 ft·lbf) at 2500 rpm in 76 kW (103 hp) at 5400 rpm, 155 N·m This is why diesels compete by fitting in turbos and then compare them with non turbo petrol cars.
so let us compare equivalent engines with turbos or with normal aspirations.
Diesels are very good and have come a long way now, but i feel the comparisons are not equivalent.
I do not want to go technical into calorific values and so on as i have already done that before.
As for lemans ,they are racing under completely different rules and that is why porsche is threatening to walk away.
Personally i think all racing cars in a particular class should all race with exactly the same rules.
Diesel cars in Lemans have smaller fuel tanks and bigger capacity engines with turbos
Petrol cars have bigger fuel tanks no turbos, or smaller capacity with turbo.
Just not a clear plain field for me.
And if you check the record books ,i do not think there are diesel cars faster than similar petrol engine cars of the same size and capacity fitted with the same no of turbos.
If there is ,please let me know and i will stand corrected.
e.g Rs6 4.2L V8 twin turbo
331 kW (450 bhp) between 5700 and 6400 rpm, 560 N·m between 1950 and 5600 rpm
4.2Lv8 tdi
240 kW (326 hp) @ 3750 rpm , 650 N·m @ 1600-3500 rpm aftermarket
272 kW (370 hp) @ 4000 rpm, 750 N·m @ 1600 rpm
I know dieselman will disagree and talk about torque figures but then i am a horsepower figure man.
As for autos or manuals, if i have a toyota i might consider an auto but i have had two merc autos and they were both unreliable,
From this forum as well, most problem gearboxes are autos so personally give me a manual.
They are cheaper, less hassle and less likely to need ECU,resetting, code fault,e.t.c
And for all those talking about resale values. why do we not all go out and buy an AMG as its resale value will be better than a normal merc.
I finish by saying every man to his taste so please do not crucify me.
