BobHUK
Hello,
I've got an S210 diesel E220 CDi Estate automatic. I've had the car for around 2 1/2yrs, and last winter I had to replace all 4 glow plugs and no. 3 injector when the car became difficult to start from cold. Since then everything's been fine, but over the last couple of months I've noticed a smell of burnt diesel in the cabin, especially when stuck in traffic. To overcome the smell I've been using the air recirculation button on the dash to stop any nasty niffs from getting into the cab.
Today it was time to change the oil and filter, so I took the plastic engine covers off. When I did so it became obvious why I've been able to smell burnt diesel. Around injectors nos 1 and 4 there was a lot of black shiny stuff. I thought it was oil at first, but when I tried to wipe it away I found I couldn't.
It looked like oil, but it was hard and dry, like black plastic. However, I found that I could scrape it away with a screwdriver. So I spent the next few minutes carefully loosening and removing the black gloop from around the base of no. 1 injector so that I could try to find out where the leak was exactly.
With some difficulty and an injector removal slide hammer, I managed to get no. 1 injector out, after which I saw this sorry sight.
I managed to clean the mess away eventually, and remove the injector sealing washer from the bottom of the hole.
I've now got to do the same with the no. 4 injector, then I'm going to remove all the injectors and fit new sealing washers and securing bolts. With luck it will eventually look like this again.
Previously I'd had to replace no. 3 injector because it failed a leak-off test, and you can see the newly replaced injector in the picture above. You can also see that at that time all four injectors were clean and dry, and it's a bit of a worry to me that two other injectors have blown their seals 6,000 miles later. So when I do lift the injectors, fit new seals and mounting bolts, and refit them, I'll make sure to torque them all down to the correct tension, and in the correct order, as I've got a manual which states that the injectors have to torqued down in a particular order. According to the manual, for my four cylinder engine the sequence is 2-3-4-1.
