Diesel Smell inside cabin (W212 E350cdi)
Discussion in 'Engine' started by Turbo1, Jul 22, 2017.
  1. Turbo1
    Turbo1 Hardcore MB Enthusiast
    143
    Jun 11, 2017
    Car:
    E class
    My seven year old Mercedes E350cdi has developed an odd problem where there is a smell of diesel fuel in the car when the engine is running and the car is stopped. Truth be told it smells more of exhaust/diesel fumes.
    Now when the car is moving the smell vanishes but when stopped at the lights it builds up and can be quite bad. Not the extent where it makes you feel unwell, but enough to make you take notice and think, god that smells bad.
    I cannot see any evidence of a diesel fuel leak inside the engine bay or around the fuel filter, nor can I find evidence of injector leaks.
    What could it be?
  2. GordonTarling
    GordonTarling Hardcore MB Enthusiast
    1,674
    Jun 29, 2004
    Grantham
    Car:
    2007 E63 AMG V8 Estate
    The usual culprit for this problem is a leaking injector seal(s). Take the top cover off the engine and it should be obvious if there's one leaking when you start the engine. There's also often an associated build up of crud around the one that's leaking.
  3. OP
    OP
    Turbo1
    143
    Jun 11, 2017
    Car:
    E class
    I was concerned it could be the exhaust manifold - done this and there is no sign of this.
  4. splitpin
    splitpin Hardcore MB Enthusiast
    285
    Aug 25, 2004
    East Midlands
    Car:
    W211 E500
    Similar problem with 05 320cdi, injector seals all good.
    Not always apparent though.
  5. OP
    OP
    Turbo1
    143
    Jun 11, 2017
    Car:
    E class
    No. I cannot see signs of soot or anything in the back of the engine bay-I'll take it into a specialist place tomorrow and see what they make of the car.
    It's had two fuel leaks in the year I've had it. I hope it might be another one like that as most of the time these are inexpensive parts - the last one costing £7.
  6. rf065
    rf065 Hardcore MB Enthusiast
    3,944
    Jun 8, 2007
    Grossbritannien
    Car:
    SLC300 - C250d Estate 4 Matic & Z900rs
    Mine had this a month or two ago, flexi pipe on the exhaust had fractured and it's exhaust fumes you smell. Custom exhaust place welded a new flexi pipe in place for £70 rather than buying a new exhaust.
    Russ
  7. OP
    OP
    Turbo1
    143
    Jun 11, 2017
    Car:
    E class
    Right.
    Not a leaking injector. Garage confirmed this. No chuffing noise either - no diesel residue/tar in injector area.
    No exhaust or manifold leak. The garage advised if there was the heat shield on the rear bulkhead/engine bay would be dirty.
    The smells gone and they advised probably just a residue of diesel from the last fuel leak.
    Given I've been to Ullapool and back via Poolewe and I live in Glasgow it seems fine and no more smells stuck in traffic jams due to the massive number of roadworks/campervans/etc on the journey.
  8. DanMorgan
    DanMorgan Hardcore MB Enthusiast
    666
    Mar 7, 2012
    Cardiff
    Car:
    R129 300SL 24V, W124 300CE, W210 E55 AMG, W140 S280
    Although yours is not the injectors, I had this exact problem and the injector was leaking
  9. Druk
    Druk Administrator Staff Member
    5,309
    May 28, 2004
    Not far from Edinburgh.
    Car:
    2011 S212 E350CDi. 1981 R107 300TurboDiesel.
  10. OP
    OP
    Turbo1
    143
    Jun 11, 2017
    Car:
    E class
Share This Page
