Darrell
Hardcore MB Enthusiast
- Dec 15, 2006
- Gixxer 6, Citroen Berlingo, 911 C4S, Dacia Duster and lots of bicycles.
I’m up to 1368 calories already.
This is my data from 1/3/21. Can anybody decipher it?
I’ve got a Concept 2, it’s an awesome workout but I have to be in the mood! If I’m not feeling fit it confirms my suspicions very quickly! I’ve got a training bike set up with Zwift which is my go to for cycling but just playing around with FulGaz which has video recordings of rides. It’s a nice change but I can’t get the power to work quite right. At the moment I’m riding up 6% climbs in the big ring and almost spinning out, but only producing 200 watts so somethings not right there!An ICG IC7 spin bike, Concept 2 rowing machine, resistance bands, weights bench with dumb/bar bells, balance board, and a few other little things.
Also use a Polar Vantage V2, and my sons also use Polar monitors, to keep tabs on heart-rate, recovery status, etc...
Alongside the exercise, I have reduced alcohol (try to limit to a double measure 3-4x per week), but not really dieting per se, just being aware of what's going down the trap hatch!
A possible added side-effect is that my migraines seem to have reduced in frequency, although this w/e has been bad. Resting HR now down in the 50s and BP at 'normal' levels, without the use of medication.
I’d struggle to keep to 2500 calories bThe format is suggesting that your recommended daily input of kilocalories is 3200 / day.
Which means you're probably a 6'3" 23 year old rower, with a 31 inch waist.
General NHS recommendation for breakeven calorie consumption for a British male is 2500 kilocalories, but nutritionists generally believe that to be too much for the typical Brit.
Here's that source:
What should my daily intake of calories be?
"Hope this helps..."
Loosing weight Craig David style.Ran 5k on Monday, 4k on Tuesday, 5k on Thursday and 6k today.
13st 8lbs.
Get in.
8th Mar - 15st - 1lb1st Mar - 15st - 0lbs
15th Mar - 14st - 12lb8th Mar - 15st - 1lb
Bloody Hell, you've done well: 12 lbs (5,5 kilos) lost in five weeks.Ok, starting me diet today, I'll weigh meself once a week, every Monday.
Starting weight on,
8th Feb - 15st - 10lb
Out of curiosity, I weighed myself today. Glad, I think, that I did; now down by 23lbs since Jan 11th.
It's the new WeightWatchers patch,Did you cut off a leg, or stitch up your mouth ? That's a kilo a week.
Lots of hard work in the gym. Doing between 8-12 hours per week. Not particularly dieting, though I have cut back a bit on Al's keyhole!Did you cut off a leg, or stitch up your mouth ? That's a kilo a week.
22nd Mar - 14st - 10lb15th Mar - 14st - 12lb
Can’t wait for the gym and pool to reopen.Lots of hard work in the gym. Doing between 8-12 hours per week. Not particularly dieting, though I have cut back a bit on Al's keyhole!
