Difference between C124 FL and PFL front windscreen
Discussion in 'Bodywork' started by Alar, Apr 21, 2016.
  1. Alar
    Alar New Member
    8
    Oct 18, 2015
    Car:
    320CE
    Has anybody have OEM codes for PFL and FL C124 front windscreen? My 1993 320CE is currently being assembled after bodywork and paint. I ordered new front and rear windscreen, but got info from my bodywork guy, that the fronts are different for FL and PFL car. Facelift model should have a plastic strip running in the bottom part of screen.
    Is this so? Even Pilkingtons catalogue shows only one type on glass from 1987 to 1997
  2. coupe addict
    coupe addict Hardcore MB Enthusiast
    111
    Jun 7, 2010
    penzance cornwall
    Car:
    e320 coupe 1994
    FL does for sure have the plastic strip - but did your car leave the factory as 320CE (PFL) or as E320 coupe (FL)?
    I guess only the later screen is available but will work fine on the earlier cars.
    On mine, the heavy rubber strip covering the bottom of the screen has shrunk by 15mm or so either side - are you replacing this, or is there a fitter's trick to stretching it?
Share This Page
