I had a S500L and the rear passenger area was cavernous...and, in case it's not obvious, 'L' stands for Long Wheel Base (aka LWB) which is the 'limo' version with the stretched body.
Yes and thank you for clarifying....and, in case it's not obvious, 'L' stands for Long Wheel Base (aka LWB) which is the 'limo' version with the stretched body.
It may be easier to work out the pros and cons of each Mercedes model by looking specifically at the engine. Mercedes diesel engine are known by the OM moniker so find out which OM diesel engine is in each car and go from there.Hi
I have been trying to find out what the difference is between the two
S class 350L D and S Class 350L CDI
Thank you for the advice. I will have a look at both OM engines and put my findings on this thread fot anyone else.It may be easier to work out the pros and cons of each Mercedes model by looking specifically at the engine. Mercedes diesel engine are known by the OM moniker so find out which OM diesel engine is in each car and go from there.
For example a 350 cdi would be a OM642 engine.
Mercedes-Benz OM642 engine - Wikipedia
en.wikipedia.org
or a 350 d a OM656 engine.
Mercedes-Benz OM656 engine - Wikipedia
en.wikipedia.org
