wempetje
- Sep 24, 2019
- Location
- The Netherlands
- Mercedes Vito 112 CDI -2003 Westfalia camper
Hi all,
I've got a question. I want to replace my injectors of my Vito W638 2.2CDI 122bhp 2003. I've done some research and found out that for my type of car (engine, year, model, etc) there are like 9 different OEM numbers available. F.e. A6110701287, A6110700487, A6120700487, A6120700587, A6120700387, etc. My question is; is it a problem if I have a combination of say 2 different OEM numbers between my 4 injectors. Each injector has to be programmed to the ECU individually as I understand it.
To be clear; yes, all OEM numbers are compatible, it takes too much time to check which numbers are currently fitted in the car, I can make a great deal on 3 original mercedes benz injectors and I know I can also test them, have the refurbished, etc.
Thanks!
Thanks!
