Spitfire
Planning to remove the standard black plastic rear under-bumper trim to modify it and take a mould from the modified item in order to create my own carbon fibre 'diffuser' from it. Bought a brand new plastic trim a while back (£54 + VAT from my main dealer, surprisingly reasonable, to be perfectly honest) which will be fitted to the car while the used item is removed and modified.
There are numerous moulded-on attachment points and fixings on the black plastic trim,however there are a couple of fixing points on the extreme left/right of it which need removing before it can be detached from the car. Not entirely sure if they are large rivets (?) type of bolt head (?) or screw of some kind(?).
Before I get carried away and either drill the heads off these things (they 'could' be alloy?) or grind them off, does anybody know if they are intended to be removed/refitted or a permanent kind of fixture? Are the three tiny slots in them there for a reason, as an aid for removal? Space for feeling behind them is so tight it is difficult to figure out.
It's a bit awkward to figure out if they are a permanent fixture or removable, while laying on your back, upside-down, faffing about and feeling around on a chilly November weekend.
A couple of pics below of the offending bolt/rivet/screw head, or whatever it could be. Just trying to figure out how to remove the plastic trim with the least amount of fuss and aggro ......
Thanks for any help.
