PunkyB
- Aug 31, 2021
- Location
- UK
- W169 Classic SE A150 Berggris Metallic, Parktronic, electric folding mirrors and comfort seat pack.
Hi All,
My sister and her boyfriend want to go to Germany for Oktoberfest and I've always fancied a mild lap of the nurburgring. In the w169 A class there is no button to turn off the traction control or stability control. You can go into the service menu and put it into a dyno testing mode which means you turn off the ESP & traction control but also the abs. However there is then a speed limit of around 70 mph. Would there be any way to get a w169 to disable it's ESP without imposing a speed limiter or loosing the ABS as well?
I should shortly be getting access to das/XENTRY if anything is possible through there?
Otherwise it looks like it's going to be a real slow tour of the ring
