Disaster, please help
Reply from MB dealer, looks like I'm stuffed
Thank you for contacting us regarding a new sam unit for your C180 Kompressor but unfortunately this is no longer available to order from Mercedes and has been discontinued. I’ve done a full dealer check of the UK which came up empty in the case. We are unable to check dealers abroad but in all honesty this isn’t a part that I can imagine anywhere to still have in stock as from what I can see it was discontinued a while back.
My best advice from here would be to check for a used unit at a breakers yard or somewhere online who might be selling one or look if there are any companies that could potentially repair your current unit.
Sorry we could not source what you require this time.
VIN ( chassis number) WDD 2040 462 A 099214
Part number ; A2049005401
Thanks, so yeah I am seeing a few useds ones on ebay. I'm not sure but don't know if used ones need to be programmed too?
Assume you've already seen the only one for sale in UK on ebay?
I spent all morning, trying to trace this on ebay and face book
But hard to find this exact number match
A2049005401
Does it have to be this exact number??
Some o
There are a number of Mercedes Independant Specialists on the forum, I’m sure if you shared your issue with them they’d advise on whether the part can be repaired, or whether an alternative SAM can be used and retrofitted. They may also have access to an alternative parts provider with the part.
A2049005401
Some o
Item 150 shows several numbers for the part. If they all would plug and play I haven't a clue.
It also shows some still in production, again no clue as to how accurate the info is.
In your situation you may have to take a chance.
Fwiw, on the units I've bought 2nd hand for the 639 I've paid around £100.
I’d make sure it’s the same part number and try on eBay. If you have a good MB specialist around they may be able to source one or have one floating around.
Pressure washers on seams/welding/rivetting can wash away the protective wax layer.
A 204 545 46 01 replaced by
A 204 545 47 01 replaced by
A 204 545 64 01 replaced by
A 204 545 03 69 replaced by
A 204 545 56 01 replaced by
A 204 540 43 50 replaced by
A 204 900 54 01 current part but nla
What you want is A204900670964
Stocked in UK.
I have given up
I emailed and contacted
most
sellers and dealers and all say the same .. unavailable
will my car be a goner!!! sad as I’m attached to it. Bought it in the same
week my
daughter was born, 11 years this week!!
googled the above number and this comes up
Hi Everyone ,
The garage has removed the SAM unit and provided another number,
It's A 204 545 4401
Please see the pic enclosed within
Any advise with this new number and how is it different from the previous one (A2049005401) provided?
Did a basic google search and nothing much seems to come up
KR
Mel
I had a look, there seems to be loads of wires sticking out …
Another one popped up? It’s twice the cost. Do you think it’s worth going for this? Plus the seller has 3000+ feedback reviews
Mel
