Disk rotor offset
Mbuglass
None
Hi all, Does anyone know where I can find the rotor offset(hat height) of my brake rotors?
They are 380mm from the CLS55 with the performance pack.
Cheers.
Take a wheel off and measure it?
Not the right PP discs but if you have a trawl of the internet with the part number* might find a drawing like this example for the standard discs... Brake Disc (BOSCH , 0 986 479 654): MERCEDES-BENZ Parts - Bestpartstore.co.uk
From a quick look around Front C-Tek Brake Rotor Mercedes Benz 121.35094 [121.35094] - $999.00 : Auto Brake Center, Brake Pads, Rotors, All Cars, All Models, Free Local Delivery in Los Angeles, CA suggests 65mm presumably measured the same way as shown for the Bosch disc in the first link which'd make it 29mm from the top hat to the front face of the disc if those numbers are correct
* A2304210912 ???
Thanks hotrodder, I did manage to find a diagram of the brake assembly but no dimensions.
