Distilled/Deionised water
pachanga 231
E280 cdi sport 2007
Firstly whats the difference
Secondly should i be using this in the radaitor for topping up rather than tap water
Thirdly same as above for wind screen top up
Sent from my SM-G950F using Tapatalk
OneForTheRoad
uk.
2015 w204 c class amg sport premium +65 ford kuga 2.0 cdi zetec awd..
you really should use mercedes ready mixed coolant, distilled water is mainly used to top up batteries .any water in the washer bottle is ok .
PobodY
Stoke-on-Trent
CLK350 Sport, Nissan GTiR
A word of caution. - Because deionised water has had all the ions stripped from it, it's unexpectedly corrosive so not a great thing to add to a radiator.
Think of it this way: Tap water usually has a load of ions in it (calcium, magnesium, chloride. fluoride, etc), and although it's not saturated with them, it's a pretty stable solution. Take them all out, and there's plenty of room to pick-up more ions (such as aluminium and iron from a radiator or engine block). - Mixing a corrosion inhibitor/anti-freeze serves the additional purpose of preventing DI water from attacking the metal.
Trickythemerc
South Manchester
CLK 220 CDI Sport 2009
When I did my coolant change, I used Fricofin coolant and distilled water. Tap water contains all sorts of stuff to make it drinkable, plain old H2O tastes pretty awful. The salts and minerals in tap water can and will react with different metals and alloys, the result being rust and the water turns into electrolyte which you don't really want in a cooling system. One of the reasons you need a good engine block to chassis earth is that the water/electrolyte in the system will in time start to eat the inside of a cast iron block if not properly earthed. I have seen cylinder head studs eaten away inside the block to the point of shearing off when torqued up. I refer more specifically to straight six Jaguar engines where you have a high carbon steel stud fitted to a cast block.
OP
OP
P
pachanga 231
E280 cdi sport 2007
Some detailed responses!
So normal tap water in both compartments lol.
OneForTheRoad
uk.
proper coolant contains elements to keep it cool , you cant boil it unlike water . hence the name " summer coolant " if you want a rusty engine that runs hot then by all means put tap water in it.
Romeo4
Dundee/Benijofar
CL500 2002.
Scottish tap water for me, you can even drink it neat. I am sure the West coast contingent on here will defend the water from Loch Katrine as I defend the supply from Lintrathen.
cheddar
Teesside
CLK63 AMG, s211 E320 CDI
I bought some genuine MB coolant recently after changing my thermostat on the CLK, on the container it actually says mix at 1:1 ratio with tap water, for protection down to -37 Celsius.
