- Nov 20, 2010
So, wanted to buy some alloys off a fellow forum member but sadly could not happen. So like all “men” looked on Ebay and decided to purchase a set and then planned to have them powder coated in a colour of choice.
EBay approach…..intentionally, bought a used set, as planned to give them to a bodyshop to refurbish AND also choose a seller close to the in-laws home…………..wife can spend time there and I could go off and “buy car stuff”.
So clicked on Ebay and arranged collection to tie in with a visit to the family.
Off I went to pay for the wheels. This set of wheels had definitely seen better days……..
The next day examined the horror wheels and realised that they were a mixture of painted and non-painted finish. I actually liked the contrast. Naturally, concluded that powder coating would result in a single finish and I would loose the shiny part. Somehow ended up thinking “refurbing a battered set surely cannot be that hard” (no drink was involved, this time!).
Okay, off we go to Youtube. A few videos later and the non-drink-induced thought pattern is:
The actual process…….
Some people will go from 400 to 1000 to 2000 grit. Suspect that it depends on your experience and state of wheel. I am new to this process and may well have wasted time/money/materials being a novice.
I went for a mixture of dry sanding and also wet-and-dry in the middle part. (As much driven by the sandpaper that I had at my disposal).
TIP You need to be patient – not a virtue that I am blessed with.
STEP 10 – once your wheel is fully smooth, finish with a cloth using metal polish of choice (I just happened to have
a tin of Autosol in a storage box) and then buff with a microfibre/cloth.
Have not got around to the next 2 steps but will over the next few weeks
STEP 11 – the wheel is now ready to be lacquered/clear coat. (I just happen to have some rattle cans left over from my last mad idea
STEP 12 – to aid future cleaning the wheel can be sealed using whatever you decide. (Have some Poorboys “pink” wheel sealant and so should use it rather than buy a ceramic sealant
Overall, for a £150 have some reasonable wheels that I may try on one of the cars. Actually, enjoy doing stuff like this and so am pleased to have learnt something new and different to my day job.
Couple of thoughts:
If you are an intermediate DIYer then rest assured that you can undertake this task. If you are a tradesperson or skilled, then it should be a doddle.
The finish on MB wheels is not flat but ever so slightly raised due to machine finish (think of it as tiny sharp mountains on a landscape). Your finish will be flat/smooth.
Cost is not the driver for me but the desire to undertake a new and different task.
- It looks reasonably straight forward
- If “he” can do it, then surely, I can also do it
- I already have a few bits and pieces in the garage (which means a few incorrect grades of wet-and-dry sandpaper BUT all “men” know that the plan is to buy more “stuff” to do a “proper job”)
- Now, where is my Amazon log in
- Wash thoroughly inside and out the absolutely filthy and disgusting wheels and let dry.
- In my case - did not see the need for masking tape.
- Select the appropriate grade of sandpaper depending on state of wheel(s) then start on a test patch. Rub past any marks ie avoiding pressing down in the problem area and thereby creating a “well”.
- Move onto next grade of sandpaper and repeat 240grit
- Move onto next grade of sandpaper and repeat 400grit
- Move onto next grade of sandpaper and repeat 800 grit
- Move onto next grade of sandpaper and repeat 1200grit
- Move onto next grade of sandpaper and repeat 2000grit
- Move onto next grade of sandpaper and repeat 3000grit
- See later
Couple of thoughts:
