DIY: How to change ABC Accumulators
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by alexanderfoti, Jan 18, 2015.
  1. alexanderfoti
    alexanderfoti Hardcore MB Enthusiast
    261
    Mar 28, 2010
    Dartford
    Car:
    W221 S65, W204 C63 + others
    Hi all
    I recently changed out all my ABC Accumulators on my 215 CL55 AMG.
    I made a guide, which should be pretty similair for all ABC equipped cars (230, 220, 215). The 230 will require more effort to get to the accumulators, but after that its the same.
    http://fotifixes.com/2015/01/18/how-...rcedes-cl-215/
    I hope it helps somebody!
    3 people like this.
  2. mattk1
    mattk1 Hardcore MB Enthusiast
    370
    Sep 1, 2011
    Guildford
    Car:
    CL55 AMG Kompressor, C350 CDI & Ducati 1299 Panigale
    Really helpful and great guide.
    Thanks , Matt :thumb:
    1 person likes this.
  3. C43AMG
    C43AMG MB Club Veteran
    6,599
    Apr 15, 2005
    Weybridge. U.K
    Car:
    500L ( W221 ), 2014 AMG CL 5.5 Biturbo ( W216 ), 2010 Brabus Smart ( Exclusive ) )
    How much of an improvement was there in the ride ? Many thanks for the write up, Peter
  4. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    30/40%
    I think the remainder of the issue is down to the top mounts of the struts. The bushes have failed on mine completely, giving play as shown in this video:
    [YOUTUBE HD]J8cltwCHr7c[/YOUTUBE HD]
    Its about 10mm of play, on both sides. That cant be good for ride quality!
    Im going to use a 10mm sheet of rubber and make my own replacement bush as its not available from Mercedes (they want you to buy a whole new strut).
    This is easy done on the fronts, but the rear strut design is slightly different and cannot be repaired (or tested) in such an easy way. If they show the same play im going to replace the struts with some used ones.
  5. C43AMG
    6,599
    Apr 15, 2005
    Weybridge. U.K
    Car:
    I will go and test mine. I have two new rear struts in the rear, so it will be interesting to see how my front bushes are.
    Please let us know how you get on and if there is any improvement. Many thanks,
  6. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    Will do! Hoping the rears aren't shot.
  7. C43AMG
    6,599
    Apr 15, 2005
    Weybridge. U.K
    Car:
    Just tested mine no movement what so ever. Solid :thumb: :thumb:
  8. m2287
    m2287 Hardcore MB Enthusiast
    2,924
    Jan 27, 2010
    cambridge
    Car:
    Bentley Continental GT
    There is another accumulator behind the drivers side front wheel also!
  9. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    That is the pulsation damper. On mine I had replaced it 3 months ago. They make a loud humming noise that follows the revs when they fail.
  10. m2287
    2,924
    Jan 27, 2010
    cambridge
    Car:
    Yea that's the one, they can also make the ABC warning light come on when you go over largish bumps, changing mine made the suspension a lot less "bouncier". It's definately something I'd do if I was changing the other three anyway!
  11. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    Lucky!!
    I have just finished putting my home made bushes in, lets see how the ride is, havent had a change to test drive it yet!
  12. MikeAMG
    MikeAMG Active Member
    73
    Oct 4, 2014
    Surrey
    Car:
    CL55 AMG
    What caused the play? Did you take some pictures?
  13. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    The play is caused when the top of the strut breaks free of its bonding with the rubber top mount, it looks like this:
    [​IMG]
    Mercedes do not sell this mount on its own, so repair would mean new struts (or the method I used).
    I did, I will be doing a write up guide shortly.
  14. MikeAMG
    73
    Oct 4, 2014
    Surrey
    Car:
    CL55 AMG
    Surprised nobody makes a strut top mount.
  15. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    I think most indy's and certainly dealers would just replace the strut, either with new, or second hand.
    Its also bonded to the top of the strut from the factory, so you would have to find a way to bond the new one onto the old strut.
  16. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    2 people like this.
  17. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    Checked today, no play on the rear shocks. So either im lucky, or they have been changed.
    I took my friends 2005 CL65 out for a drive today. It has the same wheels and same suspension as mine, however it has 40,000 miles. It drives exactly the same as mine, except mine is more crashy on the rear. Im going to do the rear subframe bushes which should have it sorted, then im leaving it alone (I promise!)
    On a side note, ******! that 65 is unbelievably torqey! It has an odd sound to it too, like a sewing machine ripping your face off, completely different drive to the v8.
  18. C43AMG
    6,599
    Apr 15, 2005
    Weybridge. U.K
    Car:
    A CL 65 a very rare beast.
  19. OP
    OP
    alexanderfoti
    261
    Mar 28, 2010
    Dartford
    Car:
    Yes indeed, only 30 odd on the roads in the UK. An amazing machine!
Share This Page
