Hello
After reading many positive reviews online about the Wurth German Silver Alloy Wheel paint products I ordered some. However I am finding the paint to be terrible.
The paint doesn't cover evenly at all and there is filament like strands of stringy bits coming out of the can. The result is patchy and coarse and uneven. If you spray it on at 20-25 CM distance as per the instructions on the can, I end up with a greyish looking colour not silver, coarse finish with bits in it, like bad over-spray, which is not the same Wurth quality I have read about. If I spray it on much closer 2-3 inches say, then the finish is more silver in colour and smoother as you'd expect, but you can't spray paint on properly at that close range.
It just doesn't seem to cover evenly and smooth no matter what I do with the stuff and is always patchy. I have contacted Wurth directly and so far they have not been any help only saying "We have no issues with this article" meaning the codes on the can I gave them.
I have contacted the seller and hope I can get a full refund.
I've just had a new email pop in now from Wurth
"I understand your frustration but we have had no issues ref this article and goods were not purchased from Wurth Uk
In this instance it would only be your supplier that can replace your goods if faulty or out of date, pls see below ref Sale of Goods Act"
I have taken some photos:
Photo1: Primer base coat
Wurth Silver top coat: (Looks more greyish not silver)
If I gently and lightly wet sand the alloy after the top coat of silver this does remove some of the greyish bitty overspray and the wheel then looks more silver but its still patchy as hell.
Anyone else had issues with this Wurth Paint?
Any other manufacturers of Alloy Wheel paint you would recommend?
Many thanks.
Many thanks.
