Bellow
Hardcore MB Enthusiast
As per thread title. The engine in my car with 'Engineered by Mercedes-Benz' emblazoned upon it has been consuming oil at the rate of 0.5-0.7 litres / 500 miles for a while now and the suspicion has been it's gone the way of all smart Suprexes and is allowing it past the rings to burn. At this level of consumption the spark plugs can be expected to be oily and ready to foul and the advice is to rebuild the engine ASAP.
Except that when I pulled the top three plugs today they are as clean as can be - absolutely no carbonisation or oiling.
There is some oil in the intercooler but some carryover is expected. When a turbo is failing and the oil consumption rising as a consequence, can it reach this level of consumption (bear in mind it is only a 700cc engine) without it showing on the plugs?
Apart from the oil consumption, it's running well and the only other sign is oil spots on the rear panel after a 100ish mile blatt which I expect to stop now I've replaced a weeping throttle-body seal (not the cause of the high oil consumption as I damaged it investigating the high oil consumption). Could the oil spots be a clue to something else? There are no signs of leaks (other than the aforementioned weeping) so I can only assume TB seal was the cause. No engine light to indicate cat malfunction, but smarts can be using considerable amounts of oil and the cat cope.
Any ideas? More investigation of the turbo required? Car has done 60,000 miles and all but the first 4000 are by me.
