Fastcar155
Hi , any noticeable difference fitting an LSD on a road car ?
If your car is powerful enough and you drive it hard enough then it will make a noticeable difference. On the road I believe that the benefit is knowing that it’s there rather than really using it or needing it.Hi , any noticeable difference fitting an LSD on a road car ?
It depends what "work properly" means...I did read though that with mechanical LSD's you have to keep your foot in to make them work properly.
Hi , love to meet her !Maybe you need to ask an acknowledged automotive expert such as Mona Lisa Vito.
Hi , it's for road use in my case.If you are a road driver who likes to press on, you will certainly enjoy the drive with an LSD more than without, as long as the engine has enough power to use it.
The track is a different matter. I don’t rate the quaife for track work. If a torque biasing unit is the only way the Wavetrac works better as it doesn’t have the inherent weakness of the Quaife, namely both wheels must have some grip to work.
Let’s talk proper plate type LSD’s though. I removed the GKN visco lok from my m3 when I changed the ratio from 3.65:1 to 4.10:1 and replaced it with a Drexler. On the track the difference is night and day. In isolation the GKN felt pretty good, but compared to the Drexler it was very slow acting. I’m not really a drifter, but the Drexler is so quick locking that you can steer the car with tip-toe inputs of throttle at the limit. With the GKN it was big foot-fulls of gas. The finesse with the Drexler is spectacular. Should be really, I put £5.5k into that diff all told. Don’t tell my wife ffs!
