WDB124066
- Apr 17, 2009
- 1996 E320 Sportline Cabriolet x 2
I think that's how people start to die, find yourself a corner and defend it till you drop might be better...??
Which is more likely, time travellers messing with the past or aliens messing with the present?
And which is more worrying?
Are you implying that we should go back in time and prevent the aliens from landing?
Seriously? Where have you been? Just got back from a long holiday in the Middle Ages?The aliens have landed???
Time travelI'd be focusing on the megaliths rather than the time travel, you can't verify time travel so easily - you have to believe what others tell you. Where-as, with the megalith anomaly you certainly can start to verify the facts around them by yourself, e.g. why does the original build height of Khufu from bedrock to tip X the number of seconds in a day = the polar diameter [or radius, don't remember] of earth....? Why is Ramses II face statue at Luxor a perfect mirror image of itself to 2 thou and so on. Try getting to the bottom of those questions first, then move on to time travel...??
As for teleportation, I think they are doing this with atoms, or bits of atoms over 70 odd kms on the Canary Islands - could be wrong though.
If you want to get a bit closer to the truth try Carl Munck [do your own research on his background] -.....
the more you read the more you realise the location of megaliths is as mysterious as the megalith itself.
So here you have a megalith that describes the polar diameter of earth, the circumference at the equator, the rotational velocity, the centre of the earth's land mass, where the north ad south poles are, the speed of light just to name a few facts, with out getting into the meter, Pi or the square on the hypotenuse, 3,4,5 triangles or squaring the circle - all of which were solved AFTER Khufu was built, supposardly. And we think it is a tomb. FFS how dumb do you need to be before you realise something else is up. the Kings were buried in the valley of the Kings by the way.
Clearly somebody measured this planet with incredible accuracy thousands of years BC and encoded that information in stone for us to read - if only we knew how. And now we do.
Seems a lot of trouble to go to putting all that information in blocks of stone, then just leaving it to weather for a few thousand years, doesn't it? FFS how dumb was that...
Of course I believe in time travel. I didn't used to, but I came back from the future and told myself it was real, so it obviously is/was/will be...
