guydewdney
better than Park - as that holds the rear wheels only - and on a cam mechanism that CAN spring out... at least foot on brake a) the brake lights are on, and b ) the wheels are ALL held...
I leave it in D, but don't have to press the footbrake.
My car stays stationary (unless pointing downhill, when I do use the footbrake)
SBC hold has already been mentioned in this thread. If the car is stationary a second depression and then release of the footbrake holds the car from creeping or rolling forwards by maintaining brake pressure until a) the brake is pressed momentarily again, or b) the accelerator is depressed. It also has the advantage that the brake lights remain on - clearly signalling to motorists behind that the vehicle is stopped.
What I would like to know, and this isn't mentioned in the handbook, is what happens if the car is shunted from behind. Does the SBC continue to provide brake pressure (and prevent the car from causing damage to vehicles in front) or does the system detect motion and release the brake? For obvious reasons I haven't been able to test this, but I'd like to know the answer. If the system releases pressure then I will be far more inclined to use the handbrake.
Does anyone know the answer to this?
Regards,
Simon
Don't forget SBC Stop which is another option on some vehicles. Just lift off the throttle and the car will come to a halt and remain stationary until the throttle is applied.SBC hold has already been mentioned in this thread. If the car is stationary a second depression and then release of the footbrake holds the car from creeping or rolling forwards by maintaining brake pressure until a) the brake is pressed momentarily again, or b) the accelerator is depressed. It also has the advantage that the brake lights remain on - clearly signalling to motorists behind that the vehicle is stopped.
John
Hi Simon,I was looking forward to having both the SBC Hold and SBC Stop features, but found that Mercedes no longer include this in the 211 . I seem to remember there's a reason, but in principle it seemed a really sensible feature to me. Do you know why they stopped including it John?
Simon
Simon
Simon
They no longer install SBC in the newer W211. Hence no SBC hold.
