S9KSY
Now that everything works fine, I can tell you Ted that the rear interior lights do not come on or respond to front door opening.Looks like the rear light should come on If a front door is open (this should also bring on the front light)
They only respond to rear door or tailgate opening.
When I open front door, only front light turns on regardless of the position of rear light switch.
I am quite happy with this situation and frankly, I do not want the "rear" interior lights to respond to "front" door opening.
Perhaps you could confirm this if you have another look at the wiring diagrams.
Otherwise, either my car is not doing what it is supposed to do or the wiring diagram that you read is wrong or does not apply to an estate W124.
Thanks for your help and suggestions Ted.
