Apr 13, 2009 #1 M MBK Active Member Joined Aug 20, 2008 Messages 755 HI GUys, Anyone know how to remove the Dome Light on the W124s? before i go pulling on it and breaking it. Kully
Apr 13, 2009 #2 Mercedes cozy Active Member Joined Aug 6, 2006 Messages 886 Location LONDON (Near Heathrow Airport) Car Mercedes ML 320 CDI W164 KEYLESS GO / (NOW WITH STAR) Are you refering to the light unit fitted in the headlining?
Apr 13, 2009 #3 OP OP M MBK Active Member Joined Aug 20, 2008 Messages 755 yes thats the one, the map light unit.
Apr 13, 2009 #4 Mercedes cozy Active Member Joined Aug 6, 2006 Messages 886 Location LONDON (Near Heathrow Airport) Car Mercedes ML 320 CDI W164 KEYLESS GO / (NOW WITH STAR) In order to remove it, you need to push the unit either to the left or right and should slide out.
Apr 13, 2009 #5 OP OP M MBK Active Member Joined Aug 20, 2008 Messages 755 Mercedes cozy said: In order to remove it, you need to push the unit either to the left or right and should slide out. Click to expand... oh cool i'll go try that in a bit, thanks for the help, just got to clean out the temp sensor. Thanks!!:bannana:
