domestic lighting power consumption
Discussion in 'OT (OFF Topic) Forums' started by coupe deville, Dec 29, 2008.
  1. coupe deville
    coupe deville Hardcore MB Enthusiast
    786
    Aug 21, 2008
    Car:
    93 E320 coupe sportline facelift
    any electricians out there
    these two will not work with low energy lightbulbs
    1 -domestic dimmer switches- do they save money if lights are set to dim or does the electricity that is not going to the light go thru the dimmer circuitry and still have to be paid for.
    2 - touchlamps [bedside] first touch on dim, second touch on medium, third touch on full. does the dim setting use less electricity
    I am trying to save the planet, and money
  2. rf065
    rf065 Hardcore MB Enthusiast
    4,034
    Jun 8, 2007
    Grossbritannien
    Car:
    SLC300 - C250d Estate 4 Matic & Z900rs
    You can get low energy bulbs that work with dimmers now, not cheap though.
    Russ
  3. popuptoaster
    popuptoaster Hardcore MB Enthusiast
    804
    Oct 2, 2008
    Essex
    Car:
    2000 E55 AMG Estate
    most dimmers use the same power all the time, if its warm and buzzing its definately using up energy instead of sending it to the lights, lots of electrical devices with variable controls work this way as its the cheapest way to build them.
  4. MBManInKen
    MBManInKen Hardcore MB Enthusiast
    3,375
    Feb 10, 2007
    London
    Car:
    Mercedes S500 LWB (V220)
    Standard dimmers will not work with real energy saving bulbs (which are in essence fluorescent tubes). There are special dimmer circuits for such lamps, but those require a suitable bulb and they are expensive.
    There are also so-called low energy halogen bulbs on the market which offer around 30% energy savings compared to incandescent light bulbs. They don't really offer the savings of a proper energy saving bulb, but they can be dimmed with the right dimmer (but be careful with the current they draw and the heat they generate).
  5. Engineered
    Engineered New Member
    28
    Dec 31, 2007
    Hertfordshire, UK
    Car:
    CLK320 (W209)
    Personally, I find "energy saving" bulbs dim enough without any fancy dimmer switches.
    Unintential consequences - I put some of these bulbs in some lesser used rooms (utility, wc, study) and find, since doing this, the family leave these lights on all the time. Apparantly, they can't wait the three minutes or so for them to warm up and attain reasonable brightness.
    I must say that I do, myself, find it iritating to go in the study for a document and have to wait so long for the light to get bright enough to see what I'm looking for.
    Maybe I'm using too cheap bulbs, but these 10 Watt jobbies, burning all evening use loads more power than the old 60 or 100 Watt which were burning for a couple of minutes each time one of us entered a room.
    Doug
  6. Carrotchomper
    Carrotchomper Hardcore MB Enthusiast
    1,234
    May 19, 2006
    Bristol
    Car:
    Audi A8 4.2 Quattro
    The newer generation ones do seem to be better for this.
  7. Dryce
    Dryce MB Club Veteran
    7,175
    May 17, 2006
    Car:
    I updated the computers in my study to new quiet low power units.
    This winter I've switched on the radiator for the first time since '97.
    As a result I'm expecting our gas usage (and by implication CO2 emissions from the central heating boiler) to go up.
  8. Corrado
    Corrado Hardcore MB Enthusiast
    221
    Nov 28, 2007
    Sussex Coast
    Car:
    Civit 1.8VTEC
    Popup, this isn't quite right:( . Dimmers for normal incandescent (filament) lighting work by switching the power to the bulb at variable points in each AC cycle. The switching means that only a very small amount of power is dissipated at the switch/control.
    So back to the Banditdave's first question; dimmed lighting using incandescent bulbs will use less electricity than if it were on at full brightness, so your meter will record that less power is used and you'll pay accordingly:) .
  9. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    This will only be the case during the time when you actually need to heat the room and not all year round.
    In addition the boiler is fairly efficient and gas produces less Co2 than the equivelant electricity generation so you will still be reducing your overall emissions.
    Time to insulate...:)
  10. Engineered
    28
    Dec 31, 2007
    Hertfordshire, UK
    Car:
    CLK320 (W209)
    I thought this must be the case.
    If dimmer switches used the same power when dimmed, there would be enormous heat within the switch (similar to that of an incandescent bulb). If not, where would the surplus energy go?
    Doug
  11. 230K
    230K Hardcore MB Enthusiast
    2,190
    Jun 1, 2003
    Belfast
    Car:
    09 E320 cdi Sport Estate, 98 E300TD Estate, 99 SL 500
  12. ukcodger
    ukcodger Hardcore MB Enthusiast
    179
    Feb 7, 2008
    Car:
    CLK W209 320 CDI Sport
    Thyristor controls which chop the waveform were introduced in the 1960's so it's a safe bet that next-to-no dimmers on the market are resistor (heat dissipating) type. So the answer is that a lamp on a modern dimmer will use less power when dimmed.
    I've started using the new halogen lamps which are in a standard GLS lamp body. (Like a car bulb within a bulb but 230 volt if that's clear). The advantages are a 25% energy reduction over the old bulbs, instant start up and they are dimmable with ordinary dimmers straight out of the box. I know the compact fluorescents give the best energy savings but in my opinion they're not suitable for every location in a house.
  13. janner
    janner Hardcore MB Enthusiast
    2,816
    Oct 13, 2003
    Car:
    E320 Turbo Technics
    Just thinking aloud...if you use a dimmer switch to save money but only dim the lights occasionally are you actually saving anything because, presumably, the dimmer switch is not 100% efficient at the max setting that you usually use?
  14. ukcodger
    179
    Feb 7, 2008
    Car:
    I would also think that the dimmer is wasting a small amount of power on full brightness. But if you do dim from time to time you'll possibly get it back.
  15. popuptoaster
    804
    Oct 2, 2008
    Essex
    Car:
    2000 E55 AMG Estate
    dont forget to add in the extra cost of buying the dimmer in the first place.
  16. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    hmm this is maybe why my outside lights dont want to work when I wire in a photocell?!
    I opted for energy saving bulbs... Im going to have a look at it tomorrow if its not too cold...
  17. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    It depends on the photocell. Some may require the lamps to be drawing current but most won't.
    I've got CFL's working on photocell/timer config.
    http://cpc.farnell.com/unbranded/pec300t/thermal-photocell-nema-socket/dp/LA02227
  18. Dryce
    7,175
    May 17, 2006
    Car:
    I'm quite sure that my boiler isn't as efficient as a modern power station. It certainly produces more CO2 than nuclear or wind. (This is Scotland - we get quite a bit of the nuclear stuff and wind stuff and hydro stuff as a proportion of our overall supply).
    The house is double glazed and insulated. That was the reason my office was quite comfortable in winter with the waste energy from the old kit.
    I will be saving energy over the summer but I doubt I'm saving much over the winter with my cooler kit.
  19. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    If your boiler is less energy efficient than a power station and produces less Co2 then it must be really bad.
    Power stations are about 30-40% efficient and dust to dust nuclear is supposed to produce the same or more Co2 than Gas.
    A modern boiler at 90+% is a very efficient product.
  20. BTB 500
    BTB 500 MB Club Veteran
    18,737
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, W639 Vito 120, S203 C230
    Motion sensor and photocell switches do often say not for use with low energy bulbs. However I've had one in my garage PIR light for 6 months without any problems so far.
    You can get energy-saving bulbs with a built-in photocell ... they're not even that expensive (think I paid about £7.99 each). I've got them in 4 outside lights. Google for "dusk to dawn energy saver".
Share This Page
