Door Check Strap
fnkhan68
London
1993 Mercedes 320e and 2000 BMW E39 523i
As the above title suggests the strap has come off from inside the drivers door making a horrible creaking sound everytime it is opened. Can someone please tell me if tis a case of stripping down the door and tightning some bolts or do i need a new bracket? Thanks.
New check strap is needed I suspect. Remember they come unpainted.
I got the main dealer to replace the check strap on my R129 recently ... was about £80 all in IIRC (with 'old car' discount).
Check strap is about £15. I would think the R129 one is the same as a W124 one
The only tough thing about fitting them is driving out the hinge pin. They can be a little tight. A long drift and a hammer with a small head are needed. It also helps to remove the retaining clip at the bottom of the pin before starting...
Nick Froome
www.w124.co.uk
Thanks for that Nick, that's what needs doing on the passenger door of mine!
Yup, it was £14.95 plus VAT.
