Door mirror lube?
mr tibbs
Desborough, Northants
S211 E320 Estate
Hi all. Can anyone advise me how to lubricate the door mirrors on our 211 E320 55 reg please? When they are opening and closing they make a real cranky noise and I would like to sort it out.
TIA
Keith
clk320x
Hardcore MB Enthusiast
East Midlands
W212 E250 CDI Sport - S211 E320 CDI Avantgarde - S203 C32 AMG
TIA
Keith
Hi Keith,
Mine did the same, just order any PTFE lubricant. Then spray the rubbers and mechanism generously.
It made mine quiet for a while, but the sound has come back now (a few months later)
This is the one I used: Everbuild P19SILSPRAY Plumbers Super Silicone Spray, Multi-Colour, 200 ml https://www.amazon.co.uk/dp/B002HMW336/?tag=amazon0e9db-21
Abs
clk320x
East Midlands
I give mine a squirt of WD40
WD-40 isn't actually a true lubricant. WD stands for "water displacing" and its main use is as a solvent or rust dissolver“
GLK
Bozeat, Northants
A200 Sports Coupé C169
It will also attract dirt, dust, etc.
Silicone, Lithium or Molybdenum grease is better, as above.
Moly grease is black, so might look better on some black plastic; Silicone is clear, of course, so works everywhere.
clk320x
East Midlands
Personally I would switch the auto inny outy mirror function as the wires will break sooner rather than later on a W211.
10000000% right, looking through the history the wires have been fixed 2 times on mine.
They are playing up again already, sometimes the passenger side mirror won’t move back up by itself (after moving downwards when reversing)
Im sure it’s the wire. Need to get that sorted.
DrFeelgood
BMW 740Li
They are playing up again already, had a star error for adjustment. Sometimes they passenger side won’t move back up following switching to drive after reversing. It’s the wire I’m sure. Need to get that sorted.
Or just leave them open all the time.
clk320x
East Midlands
I would, but there are idiots who can’t drive down a road without smashing my mirror! :)
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
I used dry PTFE lube as used on MTB chains, best for avoiding grit build up.
Salal
London
W211 E320cdi Estate, W210 E200K, W209 CLK220. Previous:W203,W202 & Smart W451
Id be a bit more careful with using lithium grease as most of them are petroleum based which can damage rubber parts/seals. Although the effect isn't immediate, overtime depending on the rubber type, it can prematurely deteriorate them and case other related issues as you find with rubber...
The best practice is to use a silicone based grease as it won't affect it and is rubber friendly, and if anything it will preserve/protect them as well which I use for many other applications and for my mirrors as I've got the same issue as well.
sturgeon
ML350 Sport CDI BlueEfficiency
Silicon lubricant every time where rubber is involved or is within striking distance!
Trickythemerc
South Manchester
CLK 220 CDI Sport 2009
I have just done a power fold mirror rebuild and there is no rubber anywhere near the pivot point it's just a metal to metal set up, probably why they get so stiff, I used a smear of lithium grease on mine. I also repacked the gearbox with grease as it was bone dry.
clk320x
East Midlands
It’s different on a 211 to a 209. I’d know I have both :)
Salal
London
Yeah on the pre-facelift W211 the noise is usually caused by the rubber lip seal between the mirror housing and door frame which is where silicone grease is ideal for. For the rest of the mechanism inside I use a lithium based grease or oil as well.
