Door strip vinyl or remove
A250 Bennyboy
Northwest UK
A Class A250 w176
Hiya all
Has or is it possible to vinyl wrap the aluminium door strips, or does anyone know how hard they are to remove, is it a simple DIY jobbie?
Will I need to get a set of trim removal tools
Cheers
Yes it should be possible to wrap them, just ask for a few quotes from local wrapping firms.
Seen it on a few MBs now and thinking it's an easy simple mod, but a bit unsure how it's removed? Is it a easy DIY jobbie? just need to know if it's removable with out damaging it or taking parts off? Door cards and the like? Cheers for any info or advice cheers
Very easy, at least on ther ML...
Just remove the interior door trim and the strips just bolt-on from behind.
I vinyl wrapped mine with a Burr-Walnut design and it looks very convincing. The brushed Aluminium strips that were standard looked very utilitarian and down-market, like a BMW.
Even a small amount of wood gives a lot of relief and makes the interior a much more welcoming place.
Cheers for the info much appreciated, I'll have a look at doing them when I finish work, going do mine in gloss black
Cheers
I will investigate my w204 also thanks
