DOT rating of brake fluid in 2003 ML?
Bobby Dazzler
MB Master
Mittel England
Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
Changed the pads today and had to draw off some excess brake fluid, and I was absolutely paranoid about spilling drops.
Done some research and found several sources (google.co.uk: brake fluid paint) that suggest that glycol-based (DOT 3 and DOT 4) brake fluid strips paint - as per normal thinking. However, also several sites suggest that silicone-based (DOT 5) brake fluid doesn't affect paint at all.
Any idea which would be used when the vehicle was being built, ie glycol/silicon DOT3/4/5?? (2003 ML270CDi)
All thoughts gratefully received, as usual.
Dot 4.
DOT 5 is not for road vehicles as it doesn't absorb moisture.
Dieselman said:
Dot 4.
Shame as it seems DOT 5 is a little more forgiving if you have a mishap!!
When syphoning, a little dripped down on to something below (chassis rail??) - I'm hoping it won't have caused any damage as it's not painted with exterior paint. Anyone with any thoughts??
Spoke to someone today who thinks that DOT 3 and DOT 4 is only bad news for cellulose paints and not water-based paints. Anyone know for sure??
