rob-hill-1
Im considering taking my '08 Mercedes Sprinter to an independent garage to have an 'invisible' delete and reprogram on the DPF for £400
I have taken my van to a Mercedes garage several times to try and figure out what has been the cause of thick white smoke which appears after every 150 miles or so in cycles, accompanied by the smell of fumes (typically when idling) They went over it with a fine toothcomb and told me it was to do with the DPF / remapping.
I had my van re mapped to stock settings at an independent garage and this solved the problem for a good 1000 miles or so. The problem then came back and the smoke + fumes is appearing after approx 150 miles again + hanging around for about 50 miles before dissapearing.
On one of my original posts, a user recommended the 'delete and recode' to solve my issue. I was wondering how many of you have done it / if it has eliminated the problem for you entireley / if it has given you any extra problems?
thanks everybody
Rob.
thanks everybody
Rob.
