DPF or not ??
sspeed
Near Blackpool..... But not TOO near !!
2006 CLK320 CDi
Hi Everyone,
If possible I would like some of you gurus out there to do your magic by retrieving the data for a car I am interested in.
It is a C320 CDi (2007 W203) with 40,500 miles on the clock..
I would very much appreciate it if you could retrieve the data card for me so we can tell if it has a dreaded DPF fitted.
The VIN is:
WDC2030202R208288
It is supposed to be a 2007 model..
I have allready mentioned in another post that I went for a test drive and there is a fault with it. One or two of you suspect the Inlet port shut Off motor from the symptoms i gave..
Thanks in advance for any help..
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
datacard below
  • sspeed C320.pdf
Bristol
Mercedes-Benz C320CDI & SLR McLaren Coupe
Simon, delivery dates and registration dates are 2 totally different things, it may have been ordered and then the order got cancelled so it sat around for a while before someone bought it or a dealer registered it on the road, doesn't make much difference really.
Being a 320CDI V6 it will have a DPF I would think.
DITTRICH
London
S205 C200SE & W202 C230K
Diesel foreign registered cars entering german umwelt zones must be first registered after 01/01/2006 or be euro 4 compliant (ie with a dpf). The fine is 40 euros every time it is spotted. Only a factor if you go to germany. My w124 diesel can no longer enter quite a few cities without "risk".
