thanks for that. 230k on engine, ran cold, tried air filter on and off. egr was great really. tiny bit of build up. stranded on a farm without code reader so trying to do it the old way. plenty of fuel. diesel getting to injectors. kept air box on without filter so sensors are on.How many miles on the engine?
Is this hot or cold? (assuming cold because you can't run it to get it hot)
Have you checked the air filters?
What code scanner have you used?
Could it be low on fuel?
When it was off how dirty was the EGR? Could the air intakes be fully of thick oil slime gunk?
