Drain plug oil filter housing Om646
Thanks Pete for your quick response.
I’m thinking of attaching an oil pressure gauge then with an adapter M12x 1.5 to 1/8 NPT as I have already purchased the set.
Just wondering if anyone else has fitted an oil pressure sensor with a cockpit gauge to an Om646 motor w204 T 2008?
Kind regards Steve.
Thanks Pete for the link, have a great day.
Hi Steve. How did you get on with fitting the oil pressure gauge ? I have the OM646 motor in my CLK and fancy fitting an oil pressure gauge when my arthritis gives me a break. I have the VDO cockpit vision gauge and sender unit, but need to work out what fittings I need. Having said that I haven't checked for a test port in the front cover yet so I just hope that MB didn't change the design or I could be in problems.
Any help with fittings would be great thanks.
Richard
