DRAIN RODDING POINT SCREWS
grober
MB Master
Perth, Scotland
W204 ESTATE
ANYONE know the dimensions /thread size etc of these old aluminium rodding point cover screws and are they still available?
Hard to say.
Well it's countersunk and if it may be 1/4" UNC
Hard to tell from a pic
Also if you get a screw and its galv or stainless you will get a reaction between dis-similar metals so put some copper slip on the threads which should help you get it out in the future. I dont think length of screw will be too important aslong as you have clearance for a longer screw
Is there enough 'meat' on the housing to drill them out and install metric thread inserts ? Bit extreme I know .
Or try these guys.
Should be easy to find them in a good hardware store , even if you have to cut them down.
I agree , but try finding a 'real' hardware store these days. My local one is now a small group of new build flats . Thankfully they still exist but are going the same way as Fishmongers/Butchers and bakeries these days. :( PS , I am not a pensioner longing for the 'old days' :D
They're selling rodding point screws in Asda?
🤣🤣🤣 Dry cleaning , Key cutting & shoe repair, Pharmacy , Off Licence , clothing , bedding , kitchenware , Home electrics , Fuel , outdoor furniture , plants , AND newspapers & magazines ..!
Useful hardware has to be next !!
Measure the outer diameter of the thread - that is its M 'number.
Measure the length of the threaded portion and divide it by the number of threads - that is its pitch.
Cross refer on chart below.
ISO 262 selected sizes for screws, bolts and nuts
CoarseFineCoarseFine
Nominal
diameter,
D (mm)
SeriesPitch,
P (mm)
Nominal
diameter,
D (mm)
SeriesPitch,
P (mm)
1R100.250.2
1.2R100.250.216R1021.5
1.4R200.30.218R202.52 or 1.5
1.6R100.350.220R102.52 or 1.5
1.8R200.350.222R202.52 or 1.5
2R100.40.2524R1032
2.5R100.450.3527R2032
3R100.50.3530R103.52
3.5R200.60.3533R203.52
4R100.70.536R1043
5R100.80.539R2043
5.5[a][8]R200.90.542R104.53
6R1010.7545R204.53
7R2010.7548R1053
8R101.251 or 0.7552R2054
10R101.51.25 or 156R105.54
12R101.751.5 or 1.2560R205.54
14R2021.564R1064
If not 'exact' then refer to possible imperial sizes and convert the given dimensions in inches to mm and compare with your measurements.
Once you have the thread and diameter, search for countersunk set screw.
would stainless self tappers be easier
or pop round to your neighbours garden when its dark........
Come on ,,this is not a mercedes screw ..Just a normal screw pull one out and inspect it .I would have one in my garage but longer than is needed . I never saw the postage times .
