Drainage holes C Class 220d coupe 2017
Colinincymru
wales
c220d amg line
At least a pint of water pours out of my drivers door at bottom when opening.
Is this normal?
Definitely no... sounds like there is a clog within the door. You will need to remove the door card to investigate.
Not quite the same problem I have..Friends 2010 E class Coupe, has water collecting in the sill panels..he can hear it sloshing about when he stops the car. He removed the screws holding the plastic bit's at the jacking points,and several litres of water poured out. Anyone have a similar experience? And more importantly a solution?
Thanks.
