Planning to change the ATF on my brother's S203 this weekend, and going to empty/flush the TC as well. Few questions...
- when you disconnect the cooler feed pipe from the TC, how much force does the oil come out at (from the TC) - ie do I need to put a funnel or pipe up to the hole to catch the oil, or is a drain pan underneath sufficient?
- anyone know what the torque rating is for the banjo bolt on the oil cooler pipe?
- any reason NOT to use Febi ATF oil (approved to MB 236.14) which is far cheaper from ECP, compared to the MB fluid?
Thanks-in-advance
Thanks-in-advance
