joe prosser
My wife went to pull away the lights and heard felt a loud thump. The car (W124 estate automatic) failed to move. I towed the car home and found that the near side drive shaft had sheared just inside the rubber boot (see picture). My wife suggested that if it broke on one side it was possible that not before long the other would go the same way and so I ordered two new drive shafts from J&R at £110 the pair (Part #DS687). Shafts arrived next day, excellent! I dutifully put the car up on stands and swapped out both drive shafts. I torqued up the diff connecting bolts to 70Nm and lowered the car to the ground. Torqued the spline shaft nut to 200Nm on drivers side, but when I did the near side I thought I heard a click from the torque wrench but it did not feel quite right. It turns out that the spline shaft had simply pulled right off the end of the constant velocity joint (see picture). I put the old, intact, shaft back on since it was operating smoothly. It was a sod of job and if I have to this again I will go for the SKF (VKJC 3244) at three times the price, believe me its worth it.
