Drivers Heatd Mirror isn't working
rirhill
Yorkshire Dales
Mercedes E350 CDI Estate
Drivers Heatd Mirror isn t working
Any of you chaps know the inside working of the drivers heated mirror. The passenger one is working. Any ideas or how do you get into the inside working so I can check the connections. Also it moves ok electrically so I am wondering if while adjusting it has pulled a connection off. Could it be the fuse and is it the same fuse as passenger mirror?
Thanks for your ideas
Ian
Ian
Instructions to remove the mirror & glass are here
http://mbclub.co.uk/forums/showthread.php?t=4374 (same as 202)
There is a connector on the rear side of the glass with wires going off to control the heating. Possible that its come off, but its quite a tight fit, so I'd say unlikely. Worth checking fuses first though - although can't tell you which one to check !
Good luck anyway
S.
**EDIT - moved to electronics section**
Thanks Sym
Don t suppose you know which fuse does what as I can t see it in the manuals?
Ian
Good luck anyway
S.
rirhill said:
Thanks Sym
Ian
No ? Should be in there somewhere. If not, is the fusebox labelled at all / symbols ? I'd check by pulling some fuses for you on mine, but I know the 210 has a totally different fuse box set-up.
S.
Thanks mate. I managed to find the fuse but it is the same fuse that works the movement of the mirror and that works. I guess it must need another glass with the heated. :(
Thanks again
Ian
