Dry Injectors
Benzdad
:confused: My 1991 190E 2.6L (W201 M103) has no fuel at the injectors. A fuel pressure test at the fuel distributor shows very high pressures +100 psi (8 bar). Since the fuel distributor works on a differential pressure scheme could this high pressure be the cause? It looks like the pressure regulator is near the fuel distributor. Any info would be appriciated.
IIRC, the KE-Jet system has a solenoid valve that cuts the fuel supply whenever you coast (i.e. going downhill, in gear, without your foot on the gas pedal).
This was designed to improve mileage / fuel consumption. Could this be a faulty solenoid, closing the fuel supply all the time?
When I get home from work I will try to find where is that valve located and will report back.
OK,
This is what I got... Could be the culprit?
Some more pics I got from the same document:
http://img196.imageshack.us/img196/2791/fpreg2.jpg
http://img26.imageshack.us/img26/883/fpreg3.jpg
http://img188.imageshack.us/img188/9647/fpreg4.jpg
http://img291.imageshack.us/img291/2798/fpreg5.jpg
