Hi Guys,
Today i thought i'd have a crack at following parrot of dooms instructions on servicing my duo valve as one of the valves wasnt working, when i opened it up i found that it wasnt working because it was stuck. i followed the instructions and cleaned all the bits and lubricated. when i put it back in it worked like new, still does. But my question is that is it possible to by the little gasket that goes between the duovalve and the bit it sits on separately form MB or is it a case of buying a new duo valve. reason i ask is because my gasket has a cut in it and i suspect that water has got through and it rusted so it wouldnt move. if it is possible to buy it from MB any chance of getting a part number please.
Thank you
Kully
EDIT:- Just checked the russian site and it looks like the duo valve is sold as a single unit.
Thank you
Kully
